Anh Hùng giúp em giải bài này theo ACI 318-25 với ạ
A
rectangular concrete beam of width b
= 24 in. is limited by architectural considerations to a maximum total depth h = 16 in. It must carry a total
factored load moment M = 400 ft-kips.
Design the flexural reinforcement for this member, using compression steel if
necessary. Allow 3 in. to the center of the bars from the compression or
tension face of the beam. Material strengths are fy = 60,000 psi, and fc’
= 4000 psi. Select reinforcement to provide the needed areas, and show a sketch
of your final design, including stirrups
Chào mừng thành viên mới nhất của diễn đàn, daddesign502@gmail.com
